- M_R_E_ExplorerThe trailer is a '15 Columbus. Bedroom ac has never worked right.
- TXicemanExplorer IIMRE, the RV units are sealed and do not have charging connections. They can be installed, but to be done properly, it is not cheap. A unit losing its charge is not a common failure mode. You need to do further diagnostics before you go down that path.
How old are the units?
Ken - M_R_E_ExplorerDometic ACs and Dometic control center 2 thermostat. They both start and shut off when temperature is met. Must need to recharge it. Don't know if you can recharge RV ACs?
- TXicemanExplorer IIBrand and model of A/C and thermostat will help us that do not own that brand of trailer.
Next, are you getting power to the bedroom unit, is compressor running, is blower running, is thermostat set correctly? Lots of info needed to help you.
Ken - WILDEBILL308Explorer IIHave you checked the thermostat to make shure it is set to the right "mode"?
Bill - sayoungExplorerRefrigerant leak, locked compressor, bad run capacitor, bad thermostat, open overload just for starters.
About Fifth Wheel Group
19,040 PostsLatest Activity: Jul 08, 2013
