valhalla360 wrote:
rhagfo wrote:
valhalla360 wrote:
djgarcia wrote:
3ares wrote:
My hitch is a automatic Pullrite for shortbed trucks
To help me backup to the 5er hitch:
1) I put alignment marks on the hitch to center it
2) I put a white mark on the center of the hitch that is visible from the truck
3) Put a white mark on the center of the pin box
4) on the back window of the truck I put two red marks 1/2 inch apart dead center
5) align all white marks inside the red marks; your good to go
Right on! the only thing would add:
When backing up and the 5th. wheel hitch is about 5 inches from sliding up onto the bed hitch stop, get out and from a side view, make sure the 5th wheel trailer hitch is approx. 3 inches LOWER than the bed hitch/plate, just low enough so the trailer hitch has to slide up onto the truck hitch by pushing the truck hitch down. Just keep backing up real slow until you hear the "clunk" sound. Stop and check that the hitch lock mechanism is secure. Then put a block in front of the rear trailer tire. Make sure the front jacks are extended down about an inch from the ground. Now do the "bump" test buy driving very slowly about 4 inches in order to make sure your truck and 5th. wheel hitch is secure/locked:)
Lower, yes
3" Lower, that's a bit much.
You just need enough to ensure the pin box pushes down a bit, so you don't accidentally high hitch (ie: the pin sits on top of the jaws). You don't really want to try to lift the legs off the ground by backing into it.
I shoot for around 1" low. The truck springs absorb that while the legs stay on the ground.
While 3" may be a bit low as long as you hit the ramp on the hitch head no harm no foul! I would rather hit a tax low than a tad high.
No issue lifting the 5er a couple inches!
I have to disagree. The lower you go, the steeper the angle of the hitch head and the more it's pushing back rather than up. That can generate a lot of force before the pin slides into position. Enough force that if the wheels aren't well blocked, the trailer may roll back then fall off the hitch.
Sure, you can say you block the wheels real well...until the one time they aren't. An inch low is pretty easy and if you don't feel the truck sag a little, it's a good clue to visually verify that the pin is properly seated (which is a good idea regardless).
Disagree all you want, Close is close enough. If your wheels are not chocked well enough to take a 3" low lift they are just mot chocked.
This whole thread is crazy, hooking up id not that hard, close counts, that is part of the beauty of a 5er. I have a split rear window, use the joint in the rear-view mirror to line up the pin.
I can't believe that we can make a simple task so hard.
