sdetweil
Sep 02, 2015Explorer
ronniedean1234 wrote:
What they are trying to sell you is called Equal, I have used it in the past on many tires, works well but keep in mind that if you have to add air to any tire with Equal, it has to be filtered air so that moisture does not get into the tire, if so it will cake and become a problem for sure...been there done that...
I had the 'small beads' which appeared like a powder..
the ones I referenced are much bigger (won't fit thru valve stem)
About Fifth Wheel Group
19,035 PostsLatest Activity: Mar 21, 2026
