RobWNY wrote:
Your questions can't be answered properly. What kind of truck do you plan on using? Long bed? Short bed? How much truck you have is also going to have lots of opinions. I have a 34' 5th wheel that has a loaded weight of just under 10,000 pounds. I tow it with a Ram 3500 SRW gasser with the 6.4L Hemi. It does just fine. I can get up to around 4,000 RPM's going up steep inclines and for some that's annoying but for me it's no big deal. I don't lose any speed and I'm not always going up steep inclines! Don't even consider a half ton pickup with a 5th wheel. You'll have payload issues. Yes, 3/4 ton, 1 ton and bigger trucks have stiff suspensions and have rougher rides but they aren't terrible. You get used to it quickly. Many more will chime in and give their opinions. Provide a little more information so they will be able to give you better information in return.
Maybe I asked two many questions in the OP. The 5th wheels I an looking at are all 24-27 ft and weight lest than 9000 lbs loaded. some examples would be the Allen 212KS EXTERIOR LENGTH 24’ 6” TIRE SIZE 205/75/R15
EXTERIOR WIDTH 7’ 6” SLEEPING CAPACITY 6
EXTERIOR HEIGHT 10’ APPROX REFRIGERATOR 6’
HITCH WEIGHT 750 Pounds FRESH WATER 30 Gallon
SHIP WEIGHT 5,650 Pounds WASTE WATER 32 Gallon
CARGO CAPACITY 2,100 Pounds GRAY WATER 32 Gallon
GVWR 7,750 Pounds LPG CAPACITY 10 Gallon
AXLE WEIGHT 4,900 Pounds. At the high end would be something like the Laredo 255SRL at 27 ft UVW 7113 lbs. I want to have room in the bed to store extra water and stuff and it would appear the Goose neck set up would offer more room. I just wanted to know if this set up would be OK for such a light 5th wheel. 90 % of the time the truck would be a second vehicle so I wanted either the F150 HD or no bigger than the F250 as a truck either one can handle the pay load. I wanted to not have to remove a big hitch when not towing.
