IHnutz's avatar
IHnutz
Bathroom exhaust fan
Has anyone tried to wire the exhaust fan in the bath to come on with the light? My wife is too short (err - vertically challenged) to reach the fan switch in the vent to either turn it ON or OFF. I thought if I could wire it to come on with the light switch it would be easier for her to clear the air, so to speak. Suggestions????
  • I changed ours out. Got one that is completely quite and came with remote control.
  • I am surprised your fan doesn't have a separate switch, our 2012 Jayco HT has two switched right inside the bathroom door, one takes care of the lights and one takes care of the fan, although the fan also has a switch on it up near the ceiling. But, should be fairly easy to do, if you are fairly handy, to put in a fan switch next to the light switch. Not for me, but for a handy person.
  • My wife is just 5', but even though I installed the Vortex fan, the wife says there is no issue as her "poop" don't stink.:R
  • My short wife uses a sawed off broom handle to reach the switch. Eighteen inches works for her. Cut yours off to the length that works for your wife.
    Lakeside
  • Johno02 wrote:
    Haven't done that, but did discover that wiring for bath lights and fan generally all come from the same source. Seems to me that its just a case of wire tracing. The switch should be able to handle the extra load OK.
    I had the same issue
    Replaced the factory fan switch with a pull switch and chain long enough for DW to easily reach
    Working great and an easy fix
    Good luck!!
  • Here is an old thread that may give you some ideas, near the bottom of the first page,the VORTEX fan is a great replacement and easy to install.
    VORTEX Fan Install.
  • I couldn't fish the wire, so I just made a stick from a piece of plastic water pipe and a cap, so that DW(short) can push the on/off button. Other end is notched to raise and lower the vent cover. The stick also works when you are sitting on the john, and realize the need to open the vent and turn on the fan. Hangs on a hook next to the john. Then you could just install the power vent with a remote.
  • Haven't done that, but did discover that wiring for bath lights and fan generally all come from the same source. Seems to me that its just a case of wire tracing. The switch should be able to handle the extra load OK.
