ilvtravln
Jun 06, 2021Explorer II
CA Traveler wrote:
Idiot lights are for the salesman to explain what a great charging system the RV has...
Buy a digital voltmeter for $10-20. With a dishcarged battery the battery voltage at the battery terminals should ramp up to 14.4V (bulk charging), then hold at 14.4V while the amps taper down (absorb charging) and then volts and amps taper down to float mode of 13.6V.
There are many posts on chargers that don't charge correctly especially WFCO and many have replaced that alleged charger.
If the plates are not completely covered with water the batteries are compromised. Have the batteries load tested by a good battery shop, an auto store is not a good battery shop.
Batteries read 13.19V while plugged into power, I check the water on a regular basis, have not load tested batteries yet. Thanks
About Fifth Wheel Group
