bacil wrote:
Absolutely agree, i just did my math and i would need close to 800Ah to run the domestic fridge and some other appliances and allow for 50% discharge on batteries between the charges (daily) from geny as i dont think solar is capable to do this alone.
Are you sure about your math? A Samsung model RF197 uses about 125-150AH. So depending upon all of your loads you should be able to stay under 200AH or 4x6V batteries.
Solar depending upon it's size and with the sun shining can supply much/all of the daily usage.
Of course no A/C.
BTW One of the best investments you can make is a battery monitor so that you can do a accurate energy audit and then decide what you need.
