- timfloodExplorerafnash.com/forum Try his site, a lot of good stuff
- BlackSilverExplorerLeave it on. Then you're drawing your load from the battery and the converter just floats a charge as needed. Cleaner power, easier on the converter and the battery.
- ScottGNomadBob123 is right.
FWIW, Your Arctic Fox has a Progressive Dynamics converter/charger which will take good care of your batterys - so you can leave the switch on all the time. - Old-BiscuitExplorer IIILeave the battery cut off switch ON until you put trailer in storage for winter
With it ON the converter can keep battery charged when you are plugged into shore power and when you are not plugged into shore power the battery can provide the necessary 12V for trailer
Your 2014 Artic Fox should have a 3 stage converter/charger which does not need the battery to buffer (old vintage converters did----years ago) and it should not overcharge your battery. - BayleyExplorerThanks......I just wanted to make sure having it on wouldn't do any harm.
- bob213ExplorerUsually depends on your converter. Some require the battery to be on as a buffer. Post the brand and model and someone smarter than me will know.
- Dennis_M_MExplorerShould be on, you want to be able to use your 12 volt lighting and possibly the water pump.
About Fifth Wheel Group
19,020 PostsLatest Activity: Jul 19, 2025
