Allworth wrote:
ON mine the "OFF" position means "sorta off" or "almost off".
The emergency brake is still connected. The landing gear still works. The propane detector is still hot. There may be others that I just have not yet found. Disconnecting the ground at the battery is the only sure OFF.
Experimenting with interior lights is the way to check the positions.
A
Makes ya wonder why they even put the switch in there, doesn't it? They must have had some logic, but other than the e-brake, the logic escapes me.
Regarding ON versus OFF, some switches will be labeled with simple universal icons:
| and
0. The
| indicating a bar connecting the contacts, and the
0 indicating nil or no connection.
