jayhardy's avatar
jayhardy
Battery Issue with stored Fiver
I have recently moved my 2014 Fiver from a storage unit with electricity to a place without any. After 3 weeks I could barely put the slides out. I left nothing on but obviously something is draining. If I turn off the main switch on the powerboX will that save the power I recharge after going out this weekend? The storage guy asked me if I had a power off unit. Any advise would be appreciated.
  • It depends on where the disconnect is installed. I had a 2012 Outback tt with factory installed disconnect in the storage compartment and it turned off everything. Battery would not drain even after several months. I now have a 2015 Cougar fifth wheel With factory disconnect located on the rear wall of the outside storage and noticed the battery would drain slowly even with the disconnect off. Every thing in the trailer was off but I noticed the auto levelers still had power so there was evidently a parasitic draw there. I installed a switch at the battery box and now every thing gets shut off.
  • FWIW, my old Komfort has the disconnect right above the entry door; simple push/pull switch. As far as I can tell, it kills everything 12v =except= the slide and the landing legs. I can go months without the battery dropping much when it's off; only about 6 weeks if left hot.
    Lyle
