Toddupton
Jun 21, 2015Explorer
At 1 o-clock on the tv 7 pin connector is the 12 volt line at 7 o-clock is the ground if you have 12 volts across those 2 when the truck is running then you are getting your charge voltage. If it is not there then you need to start looking at the TV.
About Fifth Wheel Group
19,019 PostsLatest Activity: Jul 02, 2025
