revflyr
Jan 11, 2014Explorer
Battery problem
I have a new Thunderbolt 386x12 that every time I put it in storage for even a week, it will draw the battery down to where it will not have enough power to raise the gear. I always turn off the disconnect.
The dealer is telling me that even with the disconnect turned off there is still phantom draws that will run the battery down. Now that is new to me, I always thought that there should be no 12 volt power anywhere when the disconnect is off. The disconnect seems very cheap as it will override the off position some. Also when turning the switch back on, it turns the sound system on. The dealer is telling me that also happens on some of the newer sound systems. Anyone else have this issue. Thanks
