pianotuna wrote:
No.
abc40kids wrote:
I think that is what I'm gonna do (un-hook when not in use) just was concerned with the leakage on top?? Never had any charging issues and while my WFCO converter isn't the best I'm told it's not the worst. I'm guessing when it leaks on top it's possibly a bit over-heated or over-charging. If I was to go with a Progressive Dynamics converter would this possibly eliminate the possible over-charging??
I spoke to WFCO and they told me a few things to check to see if the converter is the issue. Everything I checked came back good.... I've been told by two manufactures that my leak issue is probably not an overflow issue but possibly a problem at the positive terminal, maybe a small crack?? Either way I have read the Progressive converter is better and I can get that one thru one of my suppliers so it will be with me next trip if there is an issue. I don't think my converter is bad but I've been camping many times with someone near me with a bad one so maybe I can help someone out if their's goes bad and it will be there if I need it.
