bilmarde wrote:
I have a 5th wheel stored out of state and I imagine that the battery is shot. Do I really need a new one or can I just use the old one to complete a circuit. If I should need a new one what size do I need. The battery box is large enough for two but in the years I have owned it I have only had one in the box.
You state "you imagine..." Test it first, put a meter on it, a charger with a de-sulfate setting and see if it takes a charge. Also, what are you planing? Cross country trip, or a short weekend stay. Depending on your plans you may want to consider getting a gel cell, which I feel will last much longer in storage than a wet cell. If you are going to continue long term storage a solar trickle charger may be the thing for your needs! If your current battery is dead, it could be shorted and I would not recommend using it just to complete the circuit! Good luck!
