1L243
Jul 05, 2015Explorer II
I use to be fan of the ez lube axles and although I hever had a failure or a seal blowout, I came to realize the best way to grease your bearings is to take them out every 10k and inspect them and pack them by hand..
For your info 3 squirts of grease from a gun is nothing.
If you insist on using the ez lube grease fittings it's one squirt rotate tire one squirt rotate tire until you see the new grease start to come out.
About Fifth Wheel Group
19,042 PostsLatest Activity: Aug 31, 2026
