4 eye bolts (3/8 screw) in garage ceiling joices. 4 eyebolts at lower corners on cap , they only stick out ~1 1/2, and are painted to match the cap. Back the truck into garage and use 4 rachet straps to lift just high enough to drive out from under the cap. Reverse to reinstall cap. Can do it myself in less than 10 minutes. If it will be off for awhile and I want get the cap out of the way, I made a simple 2x4 frame and added some dolly wheels. Lower cap on frame and push it anywhere you want. What works for me.
