golf_bears
May 23, 2015Explorer
Wood chip is correct, 6" should be minimum and nose high at 4"-5" is too much.
That said, your solution is to raise the your RV. Also depending on how much squat there is on the TV when hooked up you may want to consider air bags.
Look at the RV suspension system and see if there is any adjustment available that will allow the raising of the RV.
Shackle adjustment or axle flips are two common approaches. Short of that your only option may be to raise the RV by having rectangular tubes welded to the frame.
About Fifth Wheel Group
19,007 PostsLatest Activity: Feb 28, 2025
