MNRon's avatar
MNRon
Bed Rail Clearance
We just purchased a 2005 HitchHiker DA 31.5LKTG that we'll pick up in a couple weeks. I'm looking for advice on hitch installation, and clearance to the truck sides.
We have a 2013 Silverado 3500 4WD Crew Cab std bed. I plan on putting a 16K Pullrite Superglide hitch in it. Does anyone have this configuration (TV, 5er, hitch), and how are clearances etc?
I know that current pick-ups have higher sides than 10yrs ago and so I'm concerned about the height clearance. Will the 5er tow level with a standard set-up? How much bed rail clearance will I have? Will I need to consider any special issues (pullrite has a 3" height extender, or worse would I need to consider raising the trailer on the axels)?
Since the FW is a few hundred miles away it would be nice to understand these issues from someone with a similar set-up to avoid changes etc when I pick it up.
As always, thanks for the advice received on this forum.
Ron
ps - looking forward to moving from the TT to 5er forum :)
  • Only thing I can relate to is the same slider.I had to buy the pullright height extenders for my truck.( 2011 f350 srw)I only had three inches clearence which is not enough.You wont know that till you know that (or hear it)..I now have 6-7 clearence and where I park mine and the lay of the land I come within 1-11/2 inches of my rails when parking and pulling out.But you never know what road you might end up on with a bump in the right place that will bring you close to your rails.Make sure you have 5-6 inches imo..
  • Thanks for the link Old-Biscuit. Sounds like the HitchHiker might have some adjustment so hopefully I can get that all set up to tow properly before I leave Chanute. Looking forward to a 5er, and to the HitchHiker the more I read about them.
  • You won't really know for sure until you hook up.
    You may need to adjust hitch/pin box for initial tow home.
    Best to have 6" bedrail clearance min. and 5vr tow level.
    Check 5vr spring shackles for adjustment holes. My bedrail clearance was great (7") but was nose high. My HH has adjustment holes in spring shackles and I was able to reposition springs/center equalizer down (raising) trailer for level tow.
    Congrats on the 'new' HH!
    NUWA has an 'archive' section for specs/info on their trailers......LINK
