MrD
Apr 23, 2013Explorer
Bed tonneau covers
Hi all, I would like to find a hard cover that would fit over my hitch, what do you use and how do you like them, do they keep your bed dry? Thanks Mike
ependydad wrote:Lantley wrote:
As other have mentioned. My pin box will contact the track of the rolling cover in a tight unlevel turn turn.
Like tuning left as you exit my driveway.:S
The fatal damage did not occur at once. I tried to adjust and compensate during the turn. Eventually the occasional dings ruined the track and damaged the rolling cover to the point of no return.
I eventually switched to a back flip G2 cover. The back flip mounts differently and does not reduce the size of the bed as much. I prefer the design of the rolling covers like the Retrax which is why I tried to keep using it, but in the end the Retrax simply was not compatible with my pin box.
Thanks Lantley. I have a Retrax and an extended pin box. I haven't noticed a whole lot of contact, but do know that it occurs occasionally.
Guess it's another thing to watch...
