MrD's avatar
MrD
Bed tonneau covers
Hi all,
I would like to find a hard cover that would fit over my hitch, what do you use and how do you like them, do they keep your bed dry?
Thanks
Mike
  • Latner wrote:
    Fold A Cover here.
    Fold-a-Cover here as well. Folds up out of the way when I need to hook up my fifth wheel, so I don't have to remove the cover. I also have their Personal Caddy toolbox.
    I have not had any issues with water getting in the bed either.
  • I have a Pace Edwards Full Metal Jackrabbit cover. Rolls up and can be locked every 12". Keeps the bed mostly dry. Sometimes a little water gets in at the tailgate corners but not much.
    Covers my hitch fine but I do bungee the handle side down to keep the handle off the underside of the cover.. Some hitch handles stick up to high for a roll type cover. Make sure yours is below the bed rails.
  • I also have a Retrax and it works great, and if you keep it waxed it looks great all the time.
  • I have a Retrax and love it. It locks in ANY position, so I slide it just in front of the fiver pin box when towing.
    Completely hides my hitch when not.
    Not cheap, but it works well for me.
  • I use the Bakflip G2. Fold towards front for towing. Unhitch, fold back to cover hitch and locks (need a locking tailgate). Can fold all the way up to the cab to use entire bed if needed and is strong enough to stand on (IIRC 300 lb limit, but, check for sure) for cleaning the nose cap of the 5er when the bugs get bad enough. Works for me.
  • I have the same hard plastic cover Korbe has...5 years now and it's still in descent shape but I've had to replace the lift cylinders (leaked), locks and some of the hardware to to age and corrosion. The cover I have is made by Undercover (out of Missouri). They ran about $500 back then but are worth it to me. My plastic cover is about 1/4 the weight of my neighbor's fiberglass cover.
  • Truxedo Truxport. I like it a lot.
    Economical. Rolls up all the way so I can get to the small truckbox I put at the front of the bed. Quick and easy to use. Snug fit. Completely dry.
    I am hoping I can put one on my new 350 that is coming, with the Yamaha Generator I am going to have in place of the truckbox.
    Truxport
  • I use one of these, but not during campin' season. I can leave hitch in and it stays dry.
  • I have a hard cover and it works great keeping the bed dry but when I fold it up for 5er towing it sits pretty tall. I have to be very careful on tight turns on uneven ground that the trailer doesn't hit the cover.
    Mine's an EXTANG
