jdc1
Mar 21, 2022Explorer II
MFL wrote:
If you have a bit too much distance between the door, and door jam, you may be able to add a shim behind the striker plate. A piece of paint stick, or popsicle stick glued behind, stained to match, might work. Like mentioned, a new knob, with longer sliding latch may be a good fix.
As to the pocket door, that Janss mentioned, mine has a factory installed strap with snap, as I'd think many would have.
Jerry
Ditto to both answers here.
About Fifth Wheel Group
