jffnkrn
Aug 10, 2015Explorer
In Arizona there is a place called RV Salvage. They may have a set. you can go on line and do a search for RV salvage or junk yards. Also check with yo local rv store, some of the older mom and pop places may have some in stock. OR Check at the rv repair facility in your area and see if they have replaced someone elses, may be able to get a couple arms for little $$$ from them OR, do you have a steel or aluminum supplier in town that has that material and make one, or check the model and get the # and order from the manufacture. Worse case is replacing the unit. Good Luck & Be Safe
About Fifth Wheel Group
19,032 PostsLatest Activity: Jan 29, 2024
