sk734
Jan 26, 2013Explorer
BigToe wrote:
Please talk more about being able to see "when the hitch and the king pin plate separate when unhitching".
I'm not so sure I understand what you are saying... how the 1/8" difference enables you to see the B&W jaws release? Or see a slight gap between bearing plates when the landing gear has landed in position to bear the weight of the trailer?
Sounds like you've come up with a solution to something that more people might be interested in, regardless of hitch. My insufficent experience however, blinds me to the benefit, and I need a bit more help to understand and appreciate your tip better. I'm making a mental note nevertheless, but I would like to know more.
If you watch the king pin plate and the hitch plate as you are raising the the front of the 5ver up, you will see the two plates separate from each other slightly-that is the point which makes it easy to disconnect since you have no weight from the 5ver on the hitch. I hope this explains it for you.
About Fifth Wheel Group
19,042 PostsLatest Activity: Aug 31, 2026
