Cummins12V98 wrote:
Look at the B&W it simply can't drop the 5er if the pin box and hitch are touching each other and the jaws are closed and the handle is locked. With the thick jaws it makes it easy to see of you are high hitched unlike others with thin jaws.
No need for a pull test as if you do what I just mentioned that is a visual test and good enough IMHO.
I think that is the disservice that leads to these dropped fifth wheels , it takes once ,and IMO you are not excempt to this either.
I towed several years with the Reese hitch, the one they call the Elite now. One piece 1" thick one piece wrap around jaw ,as foolproof as you say the B&W is . And yes for a long time I did a pull test ,but there were times when I got complacent , and skipped the pull test, I just knew everything was done right ,visual was done , and then there is that one time when you just think everything is right , and boom you got a fifth wheel sitting on the bed of your truck .
As you know I tow with the Andersen ,you have criticized the ability to lock the Andersen ,but in reality I can just as well forget to even lock the handle . My point as you point out there are steps to follow with the B&W to insure not dropping a fifth wheel , yup all you got to do is those steps , just DON"T forget one . IMO skipping a pull test is a recipe for disaster . I may be mistaken , but doesn't B&W recommend a pull test ?
