Dustytuu's avatar
Dustytuu
Best place to order HWH
Where is best place to order 12 gallon Surburban hot water heater for 5th wheel?
Ours is leaking!
Can not see where it is leaking. It was replaced 4 years ago for same problem!
Thanks
Dusty
  • I'd pull it and have a pressure test on it. Then when you find I the leak have it welded or heliarced. About any machine shop can do it once you have it out. Like old biscuit said it is probably at a bung weld.
  • I think that I would remove it first and determine where it is leaking. It could just be a fitting. I had a leak this pass spring. Service man wanted to order a new one. I insisted that he first pull the old one out. Sure enough, the hot water fitting coming out of the top of the tank was leaking. Just a few dollars for the fitting and about an hour labor bill. Sure beat the cost of a new water heater. Just saying......
  • EBay......$350
    Amazon $372.15
    PPL $449
    AdventureRV $449
    AmericanRV $449
    Just shop Suburban SW12DE (Combinations Gas & Electric Water Heater-Direct Spark Ignition)
    No Electric Element then SW12D
    Where did old one leak from?
    Been in freezing temps?
    Tank crack?
    Only places on backside are:
    Cold water inlet
    Hot water outlet
    Front side:
    T&P Relief Valve
    Electric Element gasket
    Drain Plug
    Course any bung weld (where items are screwed in) could be cracked
