Cummins12V98
May 16, 2015Explorer III
Baja Man wrote:
Cummins....I did not want to have to remove caulking and screws to install a cover (if I simply add a cover). If I install a fantastic fan then I will definetly consider a fantastic cover as well.
All you do is remove 4 screws and put a small amount of sealant into the screw holes and then install. Very clean and simple installation compared to the others that require frilling the frame for the mounting clips.
I was doing a complete re seal at the time of the new covers.
About Fifth Wheel Group
