Any of the diagonal bracing products will do the trick. some are simpler to operate than others. I made my own JT knock offs for both our last TT and our current 5'er. On solid ground it's absolutely rock solid. On dirt/gravel it's about 90-95% solid. On both I installed the four brace system on the front and one diagonal in the rear. Wheel chocks of any kind won't take the sideways wiggle out. They help with front to back. To get the bounce out you need to make sure the rear stabs are under pressure. I do like some have suggested and that's to level up slightly nose down (1/2") and set the rears, then lift the front up to level. That puts added pressure on the rears.
