fly-boy
Jul 11, 2014Explorer
I would repair it with glass but if you are concerned about doing it I have an easy fix-
Cut out around the damaged area and fill it with expandable foam so you keep H2O out. Sand it down as flat as you can.
Then buy a 4x8 foot piece of 0.020 matte aluminum sheet with an adhesive laminate on it. Have the metal cut to run entirely across the ramp and cover the hole. It should look just fine and you will be good to go!
If you need the aluminum- PM me. I can cut and ship a sheet with the adhesive already applied so all you have to do is peel and stick.
About Fifth Wheel Group
19,040 PostsLatest Activity: Jul 08, 2013
