BigBlockTank
Aug 26, 2014Explorer
artguys wrote:
Go to West Marine , Boat US or the like. Don't buy the more expensive Epoxy fix systems...lots more expensive and it adds a extra layer of steps. Anything epoxy requires a final finish to protect from UV issues, rather choose a polyester resin fix solution, and add a coloring agent...hence no need for the extra layers of finish,as polyester resins alone can stand up to uv issues. Get a patch kit with fiber mat then buy the resin and catalyst. Leave damaged area as is and simply fill in the void with available material such as cardboard etc. The final finish doesn't require a gel coat just a series of abrasives to finish with a 2000 wet dry and polish.
Help me follow along. Are you saying to patch any fiberglass with polyester, no matter what the original substrate is made from?
And, do you know what this particular door is made from?
Thanks in advance
About Fifth Wheel Group
19,040 PostsLatest Activity: Jul 08, 2013
