davisenvy wrote:
The leaf springs are already on top of the axles. The dexter axle flip kit wouldn't do me any good. The only options I have found are bigger wheels/tires, lippert correct track and/or subframe lift.
Well you are correct. I think you will probably be the happiest with the frame lift. I still think you should go with heavy duty shacks wet bolts and extra bracing while you are at it.
It does suck that these trucks are so high.
But they do look cool.
The correct track should give you 2" is that enough?
