davisenvy wrote:
With my current set up and the 6 in subframe I should be right at 13 ft at the AC. 13.06 to be exact. Its either nose high or FW high. I'm trying to split the difference.
I'm going to call around this week because we have a busy summer planned. I'll report back with what I find.
6 inches seem like a lot. As you raise the back you will gain bed rail clearance. At some point you should be able to lower the nose(pin) to adjust for level and still have adequate bed rail clearance.
When I leveled my rig I raised the rear but I also lowered the nose.
