davisenvy wrote:
When the FW is hooked up to the truck and all 4 tires on the FW are on 3 inch blocks, the FW is 8 inches nose high. I have been talking with a gentleman on the Jayco Forum that has the exact same truck and FW as I do. He did the 6 inch subframe and has the upgraded 16 inch wheels (mine are 15 inch). His FW is still 2 inches nose high which would be very acceptable to me.
I have an appointment to take my FW in tomorrow and have the subframe put on. Before doing the subframe, the owner and a fabricator are going to look over the FW with me to see if there is any other way to achieve a level towing experience with my truck and my FW.
The extra high bed rails on the truck seem to be contributing a good bit to the problem. I'll report back after tomorrow.
I don't have all your numbers . But I believe your current bed rail clearance is 6"?
If you raise rear bed rail clearance will increase as well. Once the rear is raised you should be able to lower the nose and still have ample bed rail clearance. In other words you should not still be nose high.
