- fj12ryderExplorer IIIWell, we'll just have to agree to disagree on that one. :)
- lincsterExplorerIt will
- fj12ryderExplorer IIIHasn't happened yet. :)
- lincsterExplorerDon't use grease fittings, you will blow out the seals.
- Chuck_GailExplorerBeen using Dexter EZ-Lube fittings for many years, never had any trouble. Just use MANUAL grease gun, pump slow, and turn wheel while doing it. I use Mobil synthetic wheel bearing grease.
- rerodExplorer
Dr Quick wrote:
Any wheel bearing grease will do, just DON'T use the zerk fittings to grease the bearings. Just look at other peoples expierence and see what problems it caused. You are much better off to pack by hand and forget the zerk fittings.
Thanks for pointing that out Dr.. I was wondering if I could save time each season with a zerk caps.
A don't know about everyone, or what the recommended service intervals are. I don't believe you need to be replacing bearings and seals all the time. Iv had good luck carefully removing everything except the seals. Check the brakes. Cleaning, Re-packing and good for another 5000 miles. - fj12ryderExplorer IIII use the zerk fittings with no issues, as do lots of other people. People rarely post on a forum how well their grease fittings are working, and their trailer bearings didn't fail today. :)
- Dr_QuickExplorer IIAny wheel bearing grease will do, just DON'T use the zerk fittings to grease the bearings. Just look at other peoples expierence and see what problems it caused. You are much better off to pack by hand and forget the zerk fittings.
- tanman32225ExplorerI use Lucas brand Red and Tacky. What a great grease for bearings.
- WI_BowhunterExplorerI use standard Wheel bearing grease most of which are considered high temp. I personally like Mystic JT-7.
About Fifth Wheel Group
19,007 PostsLatest Activity: Feb 26, 2025
