olds468's avatar
olds468
Best Winter Toy hauler
Looking for a 5th wheel Toy hauler with a 14' garage, Loft so we can sleep at least 3-4 in the living area.
Need to have an artic package on this so that I can live in this during the winter in Central Indiana. This will be parked in the Winter and used during the Spring through fall for travel.
Would prefer 3 slides and a hide a bed sofa. 40+' long is ok.
I have a 2001 Ford F350 dually diesel.
Thoughts on the most energy efficient make and model out there.
ps. would like to buy used.
  • SDcampowneroperator wrote:
    You have a good truck, able to handle most anything. Trouble I see is that no MFGR. I know of built ( builds ) a toy hauler with 4 seasons in mind. Summer play things you see?
    Building for cold temps means a lot of extra weight, which would put the purpose of a toy hauler overweight.
    There is one, if you have the money. New Horizons Custom Built. Would have to trade your truck up to a highway tractor to tow one.
    Why do you want a 14' garage? For a small car? Toys only need 9'.
    If possible, consider using a second trailer or a 'tote'
    Nine feet? That's not even enough room for me to change my mind.
    Our RZR barely fit in a 9' garage, like, we had to park it against the front wall of the garage to get the rear door to close, and forget about having a spare tire that stuck out at all on the back. A RZR 4 is 12'2". So no, not all toys only need 9' :)
  • would like the 14' garage as we have a jr dragster that is 13.6' long, could go 13' or even 12' but will have to put dragster on angle from top to bottom.
    Truck is 4X2 with turbo diesel not sure of gearing my guess would be 4.10 as rpm @ 70mph is close to 2500. Crew cab Lariat version, back doors are smaller.
    13,000 lbs does limit options. Time to rethink
  • From what I find, here are the specs for your truck, 11,500 GVWR, 3922 max payload, if 4x2, you have a 13000 max 5th wheel capacity, if 4x4 you have a 12600 max 5th wheel cap with 3.73 or 4.10 gearing same either way. Your GCWR in 20,000lbs. That all is based on a crew cab with 7.3 diesel pickup. So with all that being said you will either need to upgrade your truck or downsize considerably your expectations for a 5th wheel. That info was on fords tow rating website. Feel free to double check it. Not trying to burst your bubble so to speak just want you to have realistic expectations as to what your truck can safely handle.
  • You have a good truck, able to handle most anything. Trouble I see is that no MFGR. I know of built ( builds ) a toy hauler with 4 seasons in mind. Summer play things you see?
  • Well I'll just say that if you have a single rear wheel truck then your going to be limited to a GVWR on a toy hauler of about 17K or even less because of the age of your 01. No 14ft garages on any of those that I know of. If you have a dually then that will open up a few more but because of the age of your truck, you'll still be limited because the 14ft garage models are generally heavier than what your truck will handle. The one true 14ft garage toy hauler I can think of is the new Weekend Warrior 4100 or 4250 models. There are some 16ft garage models out there also all of which I doubt your truck can handle. Most haulers that size will have a pin weight of 3600# and up which I believe narrows trucks down to a dually in the 2010 maybe up to current model years.
