- Cummins12V98Explorer III
socoguy wrote:
Cummins12V98 You could market that very nice set-up and fab.
Thanks! It was a lot of fun to design and build. I have no problem if anyone wanted to copy it. I kept the front to back dimension to where I can still get to the air bag valve. - AH64IDExplorer
jjj wrote:
I have a front hitch on my Ford that carries 3 bikes and in the dessert heat never had a air flow problem. If my sig.pic shows up it is on it.
Just to play devils advocate... what do you use to monitor the temps to verify there aren't any airflow issues?
Dash gauges don't show enough, and are not the most accurate across the board. - jjjExplorerI have a front hitch on my Ford that carries 3 bikes and in the dessert heat never had a air flow problem. If my sig.pic shows up it is on it.
- garysolExplorerI am thinking that I will be going the roof rack route. Both Thule and Yakima make nice roof mounted racks that mount to the roof of most pickups.
- socoguyExplorerCummins12V98 You could market that very nice set-up and fab.
I built this a couple years ago. Clears the bed, cab and bed height tool box. Easy to keep an eye on. Swagman XTC2 - Ed_ke6bnlExplorerI would be concerned about clearance when going through large dips in the road
- nremtp143ExplorerThere are lots of guys that have made pin box racks for short beds. Do a search and find one that you like and make it or have it made. I made my own, but I have a long bed. Anyway, I'd rather have them on the pin box.
- jasultExplorerwhat I fabbed up
- AH64IDExplorerDon't block the airflow, it's a Ford :-)
But in all seriousness the airflow and view blockage aren't worth the front of the truck.
A welded custom receiver hitch on the back of the 5er is also an option.
About Fifth Wheel Group
19,007 PostsLatest Activity: Feb 28, 2025
