klr650goldwing's avatar
Sep 04, 2013
Big mistake
A couple weeks ago we went camping and stayed at an RV park. As I backed into the campsite a branch from a tree scraped the top of the roof. It left an abrasive mark about 8 feet long. I went up on the roof after we got home and look closely at the damage. It doesn't look like there is any penetration of the rubber membrane, however, there could be the slightest pin hole that I can't see. So I'm wondering if any of you have some suggestions on what I might do to ensure there is no leak. ie. would it be smart to place some white duct tape over the scraped area. Or, is there something better for this type of application? I really don't want to take the risk of a leak. If there is some product that I could put on the roof before it rains I'd like to do it.
Thanks in advance for your help.
  • Another vote for Eternabond...clean the area, unroll the tape, apply it and never worry about it again...much faster and guaranteed to fix any leak, if there is one.
  • Yes, it is named "Liquid rubber Roof". It runs about $50. per quart and can be put on with a simple paint brush. You may be able to pick it up at a local RV supply, or dealership.
    Simple to put on:
    1. tape the area off about 4" outside the affected area.
    2. mix the catalyst into the LRR EPDM material. It has to sit about ten minutes before applying.
    3. Clean the area to be applied with denatured alcohol.
    4. When cleaned area is dry, apply the EPDM liberally.
    5. IMPORTANT, remove the masking tape before the EPDM cures!
    6. Any left over product can be stored for a while in a freezer, especially if you feel a second coat is needed. It can be applied after 24 hours.
    While you are at it, clean, tape off, and seal all lap joint protected
    penetrations of the rubber roof, such as around sky lights and vent tubes. Also where the front cap and, or rear caps meet the roof. I've used it on two trailers and had excellent results.
    Bandaid
  • I put an inch long tear I our roof and used enternabond tape to cover it. It was still on 7 years later when we changed trailers. Make sure the surface is clean and use a hard roller to help fuse the tape to the roof.
  • Eternabond
    If there is a small leak/pin hole, the Eternabond will take care of the problem.
    Clean the area well before applying.
    There was a post a few days ago, on Ebay you can buy Eternabond by the foot. Just buy what you need to make your repair.
    If you are not familiar with the product, do a forum search. There are lots of posts on the subject.
    Eternabond is a great product.
