magonzo's avatar
magonzo
Bird nest in the pin-box
So I keep the camper at a local storage lot. I went to pick it up yesterday and found a mess. Some birds built a nest in the pin-box and got bird droppings all over the place. I keep the umbilical tucked in there and it was covered.
Have any of you had this happen and what did you do to deter the birds from coming back?
  • phillyg wrote:
    Are there still eggs in the nest? You know, you can't use your FW until the little birdies leave for good.
    Wren eggs aren't too bad on a toasted English Muffin.
  • Had the same problem, took a garbage bag stuffed with wadded newspaper and shoved it into the opening after the cord was inserted. Bag will form around everything and fill the cavity. No $ spent, my favorite type of solution.
  • This is a common problem all over in the spring. A lot of different birds love those 5er pin boxes. Last year a Killdeer nested under the front of one of the 5er in storage.
  • Are there still eggs in the nest? You know, you can't use your FW until the little birdies leave for good.
  • a piece of hardware cloth stopped the house wrens. That was after we had to take a nest full to the tire store mom wasn't to pleased with us.
  • I use pieces of aluminum siding that I had laying around and formed them to fit and block the entrance into the pin box. I also use two mesh laundry bags got at the dollar store. I cut the bottom out of one and then pull it over the pin box and then put the other one over the front end of the pin box. I then use bungee cords to hold in place. When I went to take the 5er out of storage a couple of weeks ago the mesh bag at the back of the pin box was pulled down and the metal moved and there was a nest in there with three eggs. I just put the 5er back in storage used the same materials and bungeed the bags a different way, hoping that the wee buggers can't manage to get in again.
