Joeydrunk's avatar
Joeydrunk
black soot from forming outside pilot light vent?
Hi again everyone. I dint know if it's dangerous or not but the last 8 months black soot stains the trailer a couple feet above my pilot light vent and I'm wondering how to get rid if it. I read that either it's clogged with cobwebs or something or the flame is burning dirty and I need to adjust it. I'm just not sure how to go about either. I wanted to post a pic from my phone but I dint see an option for that. I have a 1990 Majorca elpaso 20 footer. Any help would be appreciated or links to detailed instructions on how to fix. I don't have any experience fixing anything like this and can't afford to have someone do it. Thanks
  • FIRST OFF.......
    You need to clean that sooted rusted disaster up :B
    Remove burner tube from gas valve and combustion chamber along with pilot flame tube and thermocouple
    Remove exhaust heat shield
    Clean burner assembly with wire brush and small bottle brush thru tube
    Scrub exhaust shield clean
    run a wire thru combustion/exhaust tube, tie rag on wire and pull it back thru several times to get soot/rust out
    Reassemble
    Loosen screw and move clamp back opening air shutter FULLY
    Fire it up
    Slowly move clamp closing off air shutter until MAIN flame is strong, steady blue flame with just a tinge of orange at tip. then tighten screw
    Should be no more sooting going on
    OR you may have to buy new pilot flame/thermocouple/burner tube assembly to make it work
  • Old-Biscuit wrote:
    FIRST OFF.......
    Reassemble
    Fire it up
    Thanks, and I sorry it took so long once again. I did most of what you said, and I took off the black sheild and cleaned a **** load of soot out and adjusted that slider on the tube. I It's allot more noise but way less yellow flame and its been about a month and there no build u like there would have been. p
  • Looks to me that it is time to invest in a new water heater. Or never leave it running while you sleep. Chris
