- Chuck_GailExplorerI use a regulator. It is my understanding that the fittings for the antisiphion valve and etc are same as rest of RV plumbing, which I believe is rated at 50 psi. I have personally seen over 100 psi at some campgrounds.
- Old-BiscuitExplorer IIII hook up regulator at the CG faucet...set for 50#....then a brass 'Y'.
Hose to black tank flush is regulated for one reason........don't want to blow flush system up (backflow preventer/connections and/or actual flush head).
Been in some places where water supply pressure was very high.......80-110#...and I sure don't want that kind of pressure on the flush system.
ALL water to rig is regulated!! - wrvondExplorer IISince the built in flushing device requires the drain valve to be open, there's no need to regulate the water pressure going in. Further, I keep all my potable water components, such as hoses, regulators, filters, etc., far away from my black water tank components.
Just sayin'... - AZ_T_TExplorer
therink wrote:
I wouldn't and don't use one when flushing tank. My tank needs all the help it can get
x2 - BumpyroadExploreras long as you are paying attention, no need for one.
bumpy - therinkExplorerI wouldn't and don't use one when flushing tank. My tank needs all the help it can get ;)
Steve
About Fifth Wheel Group
19,021 PostsLatest Activity: Jul 26, 2025
