CA Traveler wrote:
Check the water hose input screen. The outlet at the tank could be partially plugged. Fix the leak before you have dry rot.
Yeah thats a possibility. Problem is I cant find anyone that has the time to fix it or even look at it till August. Good news is Im home and won't be using the camper. I am hoping its a check valve problem. I can see a little water but not a big deal. If there were a major break there should be gallons and gallons of water laying in the enclosed belly pan of the camper. Like I said I punch a couple of holes in the pan and nothing came out. A little from under the shower pan between the linoleum and where the shower sits on the floor. I looked under the shower in the camper and the plywood is not even damp dry as a bone.
