valhalla360 wrote:
dewey02 wrote:
A holding tank is NOT a waste treatment plant and it isn't a septic tank. So comparisons to those systems is not even relevant. A holding tank is just that - a holding tank. If you've got no smell problems, just continue using a lot of water with each flush. If you've got some smell problems, then there are many products you can use. It isn't rocket science and it isn't a big deal.
And despite what is said above, commercial waste treatment plants often add chemicals to sewage to precipitate out the phosphorous (tertiary treatment) that is present in sewage and isn't removed through the aerobic biological process.
Probiotics aren't going to precipitate out the phosphorous and even if it did that would only create the problem of having a layer of phosphorous on the bottom of your holding tank.
Of course they won't, and as previously mentioned, comparison of holding tanks to sewage treatment facilities or septic systems is meaningless. And why would anyone want to remove phosphorous from their holding tank? As I said, this is a holding tank not a sewage treatment plant. The effluent in the holding tank gets treated AFTER you dump. You and I agree on almost everything in your original post with the exception of your comment about commercial sewage treatment facilities.
And now back to the main topic of this thread.
