It is likely that the solution that the op has experienced is temporary. We have been down this road and it is always the same. Unless/until you get that tank pressure washed you will have problems. Do yourself a favor and have a little piece of mind. Have the tank pressure washed. Then use plenty of water when flushing and fill the tank to the bottom of the toilet and then and only then open the black tank valve to dump. Like others have said, TP is not the problem - using to little water and improper dumping practices is.
