Omer&Donna wrote:
Thanks for suggestions. The level is inside the toilet bowl so we know it's full. Will try ice and drive around in morning then I guess a plumber with a cam is the only thing left. Several friends camping with us and everyone is baffled after working on it all day.
This doesn't mean the tank is FULL!!!
This is the infamous Pyramid of Poo!!!
It is caused by several things, not using enough water when flushing solids, leaving the drain valve open all the time, and bad pipe install.
This needs to be worked from the toilet side.as nasty as it sounds, you need to get something through the toilet into the tank to start breaking the pyramid up and get it cleaned out.
