spud1957 wrote:
Ropdoc wrote:
Hello all,
My 5th wheel is only 6 months old. I have flushed and flushed my blank tank but it will not seal. Every time I remove the cap off the end I have to have a bucket ready. I have been careful to make sure the handles are all pushed in. What else should I do?
Thanks,
Dave
If you are unable to easily access your valve to replace it. This will work http://www.campingworld.com/shopping/item/twist-on-valve/27868. It will at least allow you to connect the sewer hose and eliminate the dreaded bucket dance.
X2, solves the problem, works great and easy to install:)
