Dirtclods's avatar
Dirtclods
Explorer II
Oct 26, 2022
Blow outs and tires
How many of you have had a blow out?
I now carry two spares for my trailer. I've tried different tires and always have what the PSI is on the tire. Never had one go on any dirt roads always on the pavement.
  • arhayes wrote:
    We’ve been on the road full time for over 8 years now, have pulled the TH 65,000 miles, and have had 6 tire failures. I have always used a TPMS system and check pressure every travel day. Thing is, these rigs are heavy, our nation’s roads are in very sorry condition, and stuff happens. I carry a full spare plus always carry an extra unmounted tire because roadside assistance can mount a tire on the road. I have had 2 failures at the same time before. The front tire delaminated and the trash from it ripped the steel valve off the tire behind it.
    Btw, the myth of China bombs is just that. I’ve run into many full-timers and they have had failures with American made brands. Anyway, good luck and check your tires at each stop. You may spot an upcoming failure before it happens.
    We had a TPMS too when our tire separated. No warning, just happened, then the TPMS went off.
  • We’ve been on the road full time for over 8 years now, have pulled the TH 65,000 miles, and have had 6 tire failures. I have always used a TPMS system and check pressure every travel day. Thing is, these rigs are heavy, our nation’s roads are in very sorry condition, and stuff happens. I carry a full spare plus always carry an extra unmounted tire because roadside assistance can mount a tire on the road. I have had 2 failures at the same time before. The front tire delaminated and the trash from it ripped the steel valve off the tire behind it.
  • Haven't had a blow-out, but did have a tread separation that took out the fender, bent the steps and damaged some underbelly stuff. Insurance took care of it without question and no hesitation. After replacing the tires, we continued to have tire wear issues on one tire. At the advice of our RV tech guy, we had it aligned and that was part of the problem. We then upgraded from D load range tires to F. A G load range wouldn't fit our rig. Since that we have had ZERO problems and this has been 4 years, when with the last set of D range tires, we continually had problems every year. If you have ever read Roger Marble's RV tire articles on his blog - rvtiresafety.net, Chinese made is not the issues - over weight, improper care - including driving over the recommended speed, alignment, etc. are the issues. Note - I sent Roger pictures of our tires and the damage and from that he made the tire separation diagnosis. He's a great guy and great resource to have. Take his advice.
  • Stories of RV tire blowouts, mostly on cheap, Chinese tires, are legendary. Best advice I can provide, is get your rig weighed ready for travel, and ensure your tires are rated for the load. Adjust psi up (but never above the tire's maximum) or down, consistent with the load table. If you need a G-rated tire, Sailuns are highly recommended. In the E-rated range, the GY Endurance excels. LT tires are not generally used where ST tires are specified.
  • Switch to LT or MT tires. Stay away from the ST tires.
