Quint_Da_Man
Jul 27, 2014Explorer II
bpounds wrote:
Not easy to find, but it appears Electra was in the Ironman product line, which currently is Hercules. Just another cheap import tire most likely. Probably discontinued the brand for a good reason. Stepping up to Michelin Ribs would be wise.
Also, reducing inflation on hot days is NOT what you want to be doing. Check and set the pressures first thing in the cool morning, and don't reduce it when it gets hot.
Unlikely that alignment problem would cause this. You might indeed need an alignment, but you would see that as scrubbing on the tire tread, and unless you wore through the rubber it isn't the issue here.
Thanks for the research and advise.
About Fifth Wheel Group
19,042 PostsLatest Activity: Aug 31, 2026
