NC_Hauler
Jul 30, 2014Explorer
Quint Da Man wrote:NC Hauler wrote:
Agree that the XPS RIBS would be perfect for your needs..If want to save a little money, the Bridgestone Duravis that "me again" posted about are "as good as" the RIBS.
But I don't understand the temps under 40 degrees remark, I too had info, e-mail from Michelin and the "temps under 40 degrees" information was never mentioned. even told them where I did my towing, all of it in the mountains of NC, TN, VA and WV from March through 1st. of Dec, I had the RIBS on an 04 Coachmen Somerset, 3 slide 5er with a GVW of 14,000#, (6,000# rated axles)...I DID tow in snow a couple of times, (though not intentionally), and in temps in single digits....and again, no issues. Alway's aired to 80 psi....
I'd still recommend the XPS RIBS , WAYYY too many good reviews on this tire, no matter the temp...but, you may also want to look at the Bridgestones that "me again" spoke of in his post.
As stated by more than several, a lot of us have done tons of research and "lived and learned" about tires on TT's and 5er's...You've been given some very good information. It appears "E" rated tires will work for you with 6,000# axle ratings and a GVW of only 12,000#...rest will depend on how much money you want to spend on the tires.
Thanks and yes I'm going with the XPS RIBS for the reasons you mentioned. Lots of excellent reviews no only from this forum but the RV community in general after spending some time researching.
As I said I was only conveying what was said to me by Michelin when speaking with them on the phone about the RIB for my 5th wheel. I told them all the technical stuff about the rig and the driving conditions I could potentially be driving in during early spring and late fall in my area. I never mentioned the summer only thing, they brought up the minimun operation temp concerns, and then I pressed them on it. But like someone mentioned it might be who you talk to at Michelin as to what story you get. Glad you've had good luck with them.
I don't have them anymore, sig 5er has 7,000# rated axles, so my tire is a "G" rated tire.
BUT, I had the RIBS for over 2 and a 1/2 years, sold my 5er to a very good friend of mine and he drove the Coachmen all over the country and put an additional 4 years on the tires and I have no clue how many miles, then he replaced the RIBS with brand new RIBS...a very good tire...
About Fifth Wheel Group
19,042 PostsLatest Activity: Aug 31, 2026
