NC_Hauler
Aug 04, 2014Explorer
tomthyme wrote:
So how do I find out the PSI rating for my wheels? I assume checking the manufacturer/model spec data somewhere? I slapped G614's on my 2011 Cameo, but never thought about the wheel PSI capacity.
Thanks folks.
If on a Cameo, and the OEM tires were "G" rated tires, you should still see a placard telling you tire weight rating, size and recommended air pressure....Don't know what your 5er's GVW is or axle ratings, but Cameo is usually a heavier 5er...I'd go with 110 psi, unless you moved up a weight rating...
My 5er has 7,000# rated axles, came with GY G614's, recommended psi airing is 110. 5er has a GVW of 16,950, loaded to 16,200#. I air tires to 110 psi, per GY and manufacturer of my 5er.
About Fifth Wheel Group
19,042 PostsLatest Activity: Aug 31, 2026
