Ric_FlairExplorerMay 02, 2013BlowMax TiresMy TH is 2 months old now with OE "BlowMax" tires. I've put approximately 3,000 miles on them. I keep them aired to the 85 psi rating and check them often. I've very careful not to scrub or c...Show More
joebedfordNomad IIIMay 02, 2013I put 15000 on my OEM tires before replacing them (tread worn out).85psi? Who is the "they" to whom you refer. Don't exceed max PSI on sidewall.Rim rating is stamped or cast directly on the rim.
Related ContentGood ole BlowMax tiresBias ply vs. radial tiresTires- Tires - TiresTire PressuresTire Advice
