Ric_Flair
May 02, 2013Explorer
BlowMax Tires
My TH is 2 months old now with OE "BlowMax" tires. I've put approximately 3,000 miles on them. I keep them aired to the 85 psi rating and check them often. I've very careful not to scrub or c...
WhitehouseLV wrote:
I'd found out what the warranty is on the OEM tires. Id also keep a log & If you start seeing premature wear I'd call them & see if you can get a credit towards new tires. I did this with my first Raptor and was able to get ~75% covered towards upgraded Maxxis (15" wheels). Also as mentioned look underneath your rims should be stamped with info on it.
